need help asap Hard to crank and keep running... what can i do?
Hey I have a 1988 2.3l mustang and i've been doing some work on. But in the last fixer upper efferts the car is hard to crank and will not idle. the reason I start messing with the car was it had a slight miss in only one cylinders and I knew and had good compression and was getting spark. But since I've worked on it I have to hole the throttle for the car to keep from dieing out. Now i just replace the fuel injectors (supposed to be OEM spec) and the fuel filter, also the Plugs and wires. Any ideas to what is going on. THanks for you help!
Matt's 95 Stang
10-05-2015 07:16 AM
