how to adjust door hinges?
I am a gear head and unforunately not much of a body tech. but I have to slam the crap out of my doors to get them to close all the way, and I was wondeing if you guys had any suggestions. its a 93 fox.
RE: how to adjust door hinges?
Are the plastic sleeves still on the striker bolts? (Assuming '93 still has striker bolts, my '90 does and I had to replace them on both sides). If not, then go to the Help parts section in your local store and get new sleaves or a new striker bolt. If yes, then try loosening the bolt, and reseting it's position. If there is any up/down play in the door when it's open, you probably need new hinge pins also.
just go to a stang site and pick up a door hinge repair kit. i had to do that for my 92 and it worked out good. 25.00 at www.50resto.com
09-25-2015 06:58 PM
