timing question
Old 03-01-2006, 10:11 PM
95gt302
Default timing question
how far advanced can i time mi 95 gt w/o startin to kill mi power
95gt302 is offline
Old 03-01-2006, 10:53 PM
gspfunk
gspfunk's Avatar
Default RE: timing question
A lot of people go to 14*, but I'm pretty sure you need to use 92-93 octane gas...
gspfunk is offline
Old 03-01-2006, 11:05 PM
blksn9550h
you should only put 92 in your car anyway man its a stang.lol
blksn9550h is offline
Old 03-02-2006, 03:39 AM
Twisted
ORIGINAL: blksn9550h
With a low compression ratio
Twisted is offline
Old 03-02-2006, 03:54 AM
Predator
Yeah, I run 92 about once every 3 tanks, and then 89 or 87 normally. No "need" for high octane on a low compression v-8 like a stock stang's.
Predator is offline
Old 03-02-2006, 03:57 AM
Mstnggt89
ORIGINAL: gspfunk
Yeah 14* seems to be optimal for most people(including me) i use 91 octane all the time its the highest where i live but i also have other reasons besides timing to use higher octane.
Mstnggt89 is offline
Old 03-02-2006, 04:09 AM
ikeybmg
i agree, i run mine at 14 but if you dont run high oc. it might ping some. just valve chatter. i suggest advancing just a degree or 2 over the stock 10 degees. start at 13 and goup a degree or 2 at a time and ride it down the road and check for pings. soon as you get just a little pinging or chattering it should be just right when you throw the high octane to her. when you do if it still has a little chaatter yoou can barely retard it till it quits. youll probably be about 13 to 15 degres. good luck
ikeybmg is offline
Old 03-02-2006, 10:34 AM
Low_5.0
How about getting a timing light and do it properly...dont forget to pull the spout connector on the leftside of the engine bay!!
Low_5.0 is offline
Old 03-02-2006, 11:00 AM
ikeybmg
yea...duh, use a timing light and unplug the spout connector before you start it. im just saying, keep advancing it till it pings then put 93 in it and it should be aight.
ikeybmg is offline
CarrieS
09-01-2015 01:00 PM
GimpyHSHS
08-29-2015 06:30 PM
Calizic
08-28-2015 01:46 PM
stormesixx
08-25-2015 09:11 AM
ding56
08-14-2015 02:40 AM
Quick Reply: timing question
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
