i had an accident....
RE: i had an accident....
ORIGINAL: m1dn1teracer
i know how to drive but when the car goes into an uncontrllable spin, its hard to control, hence the term uncontrollable
No, you don't.
"so i dropped 2 gears (i was in 5th cuz i knew i had him)"
Your first mistake was doing this on a public road.
Your second mistake was going for this amount of distance.
Your third mistake was being in 5th and dropping down to 2nd gear, causing a lock up of the rear tires and causing the rear end to spin, which at the speed you were probably going, even if you hit the clutch in I doubt you would be able to recover.
You're fourth mistake is having a vehicle that is powerful enough to do this and not be able to drive it because of your skill level (lack there of).
