Clutch going out, what to replace with?
Ok, just got my 92 mustang 5.0, took it out and tested it the other day at the races. Fared quite well, but now i think my clutch is going out. The friction point only engauges when the pedal is almost fully released, and the cluth push is much harder now as well. So first, is that my clutch going out. If not, what could it be. If so, what type of clutch would be suggested. I have a lot of bolt on applications already in place, so i would probably like to go with a higher end clutch. Any suggestions would be greatly appreciated.
Logz5.0
Logz5.0
RE: Clutch going out, what to replace with?
I did the king cobra clutch its awesome, but its stiffer then most.. Make sure if you replace your clutch, to: resurface the fly wheel, replace the pilot bearing, steal bearing retainer, and if needed the rear main seal aswell..
Just to be on the safe side..
What hood is that on there.. Is that the Stalker u have on yours.. i like it a lot... Also, did that sound like my clutch was going out... Ive only had my clutches slip before when they were bad, so i dont know if that is going out for sure or nott... Thanks>!
ORIGINAL: Logz5.0
So centerforce or king cobra... any other suggestions, does anyone have any comments on these two, what is better. Not for racing necessarily, but be able to handle the pressure if i want it. ! Thanks again!
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
