EFI to CARB
EFI to CARB
[list=1]
<LI>Introduction
This article is for anyone with an '86-'95 Mustang that is contemplating converting from the Electronic Fuel Injection (EFI) to a carburetor. If you have an '84-'85 automatic fuel injected car then use the CFI to carburetor conversion article. If you see something that you would like to have added or something missing in this article just post it on the Carb'd Ford Message Board and I will look into adding it. </P>
</P>
<HR>
<LI>Why Are You Converting?
The first question you should ask yourself is why. Why do you want to go from fuel injection to carb? If your car is a daily driver that is fairly stock then you are just wasting your time and money. Your gas mileage will decrease, you will lose some low end torque, you will lose some drivability, you will increase your exhaust emissions, and decrease the value of your car. If you have a street/strip car and are looking for a cheaper way to build more power then a carb setup might be for you. If it is a race car and you don't care about drivability then a carb is a smart choice. Don't get me wrong, a good well thought out carbureted combo is a very good system. But if you are switching to a carb just to solve your problems with EFI you might be surprised. A carburetor requires work to get it right. You may be trading in your problems for a whole new set of problems that you know nothing about. Before doing anything carefully weigh out your decision to remove the factory system from your car. In the end I hope that whatever decision you make turns out to be the best for you and your car. GOOD LUCK!!!</P>
</P>
<HR>
<LI>Mechanical Changes
Intake and Carburetor: Of course if you are converting from EFI to carb you must have an intake manifold and a carburetor. Just be sure to size the components to match your combination properly. The Building the Perfect Combo article on this website can help.</P>
Fuel System: You will need a new fuel pump and pickup. Do <U>NOT</U> use the existing EFI pump. You can either use an electric low pressure pump designed for a carb (like the Holley red or blue pumps) or go with a mechanical fuel pump. In either case you must replace the fuel pickup on top of the gas tank with a purpose built pickup that does not include an in-tank pump. The Mustang Performance Handbook Vol. 1 includes plans to build your own pickup if you decide not to shell out the $100 that it takes to buy an aftermarket one. If you have a drag car it may be time to upgrade to a fuel cell or modify your existing tank for a bottom sump. At this time I also recommend you go with new fuel line from the tank to the carb. Use 3/8" minimum or larger based on your needs. Remember that many sanctioned race tracks will only allow up to 12" of rubber fuel line so go with aluminum wherever possible, and keep the lines in-between the frame rails for safety. To use a mechanical fuel pump you must change the front timing cover on the engine to one that accepts a bolt-on fuel pump. You may also need a fuel pump eccentric to drive the pump. My '88 motor had one from the factory but I have heard of some roller motors that do not have them.</P>
Ignition: Replace the distributor with one from an '85 manual transmission Mustang. This distributor has a steel gear to be compatible with a roller cam. Also use a Ford Duraspark II ignition box. Follow the Ford Duraspark II Ignition System article on this website to hook it up right. A complete MSD distributor and box could also be used as a step up from the factory stuff.</P>
Brackets & Linkage: Any fox body accelerator linkage will work as long as the car was equipped with a carbureted V8. Look for a '79-'85 V8 Mustang or an '83-'88 V8 T-bird if you go junkyard searching. You will also need the throttle cable bracket attached to the intake manifold and a throttle return spring.</P>
Transmission: This is probably the most critical step of the whole process. If you have a manual transmission you have nothing to worry about. However, if you have an AOD automatic you need a TV (throttle valve) cable. You can purchase this from Lokar Performance (NOTE: this is the same cable that Windsor-Fox Performance carries except $25 cheaper from Lokar direct). Setup is critical so follow the instructions included closely. Setting up the cable wrong will lead to a burned up transmission in very short order.</P>
</P>
<HR>
<LI>Electrical Changes
The electrical changes described here are for a 1990 Mustang. All '89-'93 mass air equipped Stangs will be very similar. '86-'88 speed density and '94-'95 mass air Stangs will also be close but some changes will be necessary. The best method to keep the wiring straight is to purchase a Chilton's Manual that includes wiring diagrams. Compare your car's wiring to the 1990 Mustang wiring. By using this outline and the correct wiring diagram the job will be much easier. I have hooked up with Amazon.com to bring everyone the best price possible on these books. Click on the cover below for more info.</P>
<TABLE width=600 align=center border=1>
<T>
<TR>
<TD align=middle><A href="http://www.amazon.com/exec/obidos/ASIN/0801985803/fletchs50carburm" target="_blank">
<FONT size=3>79-88 Mustangs</FONT></A></TD>
<TD align=middle><A href="http://www.amazon.com/exec/obidos/ASIN/0801985803/fletchs50carburm" target="_blank"><FONT size=3>
89-93 Mustangs</FONT></A></TD>
<TD align=middle><A href="http://www.amazon.com/exec/obidos/ASIN/0801988233/fletchs50carburm" target="_blank"><FONT size=3>
94-98 Mustangs</FONT></A></TD></TR>
<TR>
<TD colSpan=3>Chilton's Repair and Tune-up Guide - Detailed step-by-step instructions fill the gap between the owner's manual and the factory service manuals used by professional mechanics. Specifications, line drawings, and photographs pertaining specifically to the Mustang make tune-ups, brake jobs, general maintenance and hundreds of other repairs routine. With today's high cost for automotive repair work, this guide is the most important tool you could own.</TD></TR></T></TABLE>
Your car is divided into two harnesses; the EEC harness and the main or "chassis" harness. The EEC harness contains all of the computer related sensors, actuators, and such. It also contains some of the wiring for the air bag system. The chassis harness contains everything else; headlights, fuel pump wiring, instrument cluster, etc., etc. In order for the EEC to receive power from the battery, control fuel pump, and the airbag to work properly, the two harnesses must mesh together at some point. There are 4 of these points:</P>[list=1]
--Two connectors near the computer (passenger-side kick panel). One is green, one is gray. Both are 8-pin connectors I believe. One is rectangular and the other is round.</P>
--Two connectors near the driver's side hood hinge and right above the master cylinder. One is gray, one is black. They are both round, 8-pin connectors. One of the connectors does not utilize all 8 pi
<LI>Introduction
</P>
<HR>
</P>
<HR>
</P>
<HR>
<T>
<TR>
<TR>
RE: EFI to CARB
if you are using a 85 distributor just double check for the steel gear as some of the early 85's still had flat tappet motors,a dead giveaway is usually old style tensioner pulley and ps bracket.
bradleyb
11-27-2015 07:50 PM
Daddys Girls GTs
09-14-2015 08:46 PM
jaiidutch
09-14-2015 10:29 AM
carb, carburator, convert, converting, distributor, efi, fuel, injection, instructions, mustang, step, use
