Surging Issues...help ASAP
Ok guys...time for you all to come to the rescue once again.
My car at idle is surging a lot. When the car is cold it is worse than it is once warmed up, but it's still bad even warm.
The RPMS will surge between 500-900 and will even die once in a while.
There are no problems at ANY other time other than at idle.
I have a brand new Ford Motorcraft Throttle Position Sensor.
Any thoughts would be greatly appreciated!
RE: Surging Issues...help ASAP
i think they all do it dude..lol. nah i know mine does it and alot of my friends do too. i have a 95 and id like to know what causes it too so please help this guy yall....
I haven't had the problem, but I've read of a number of idle surges that were due to connection problems in the salt and pepper connectors. Cleaning IAC as mentioned previously is definitely a good idea. Also check for vacuum leaks, and pull the codes from the PCM to see if it has anything to tell you. Even if you're not getting a check engine light, there could be some codes.
