what should I expect?
I have a 347 stroker almost built.
It has a 3.4" Stroke/4.030 Bore/5.4" Rod----Crankshaft.
KB Hypereutectic Pistons Flat 5.400
Victor Jr. 210cc----Aluminum heads.
24lb injectors.
Edelbrock Performer RPM Intake
BBK Adjustable FPR.
If you need to know anything else to get a better idea, let me know.
What should I expect to get at the rear wheels (hp & tq)?
24lb injectors.
BBK Adjustable FPR.
RE: what should I expect?
Yup big heads for sure and you will make it work good if you pick the right cam and buzz it up with a manual tranny. Make sure you gap the top piston ring to the KB specs so the pistons live and you may want a little more injector too.
I am not sure what cam I am going to run. Any thoughts?
Maybe, COMP CAMS XTREME 270 HYD. RLR CAM & LIFTERS?
Are the heads too big? Should I get 190cc heads?
It's not too late to make changes.
Let me know what you all think...ASAP
treesloth
09-28-2015 07:03 AM
