Car not making power after 3/4 throttle
Old 03-09-2006, 01:44 PM
1fastzook
1fastzook's Avatar
Default RE: Car not making power after 3/4 throttle
i would say your computer is bad.my computer went bad before but the car wouldnt run at all and i couldnt get it to read a engine code.i would try to put a new computer in it.i think i paid $115 for a new one.
1fastzook is offline
Old 03-09-2006, 01:53 PM
88BlueGT
88BlueGT's Avatar
What kind of setup are you running ?
88BlueGT is offline
Old 03-10-2006, 12:01 AM
MattyHopper
MattyHopper's Avatar
got pretty much everything done naturally aspirated.
Edelbrok upper and lower
Mac cold air intake
70mm T.B.
70mmPro M Mass Air
underdrive pulleys
Ported and Polished heads
B 303 cam
30lb injector
2 1/2 inch exguhast
I think that about it....
MattyHopper is offline
Old 03-10-2006, 12:11 AM
ckyguy68
ckyguy68's Avatar
is a possible this could be floating valves?
ckyguy68 is offline
Old 03-10-2006, 02:37 PM
MattyHopper
I'm not to sure.... if it's possible this could be floating valves... i'll be honest and say i'm not to sure what that is....
Old 03-10-2006, 11:02 PM
HAUS
HAUS's Avatar
why 30lb injectors???
HAUS is offline
Old 03-10-2006, 11:04 PM
ikeybmg
ikeybmg's Avatar
if youre going to use those 30lb inj. which you dont neeed. to should get an adjustable fpr. so you can tone it down a little.
ikeybmg is offline
Old 03-11-2006, 01:34 PM
MattyHopper
planning on putting a supercharger on this year...so that's why i got 30lb injectors
Old 03-11-2006, 01:39 PM
HAUS
HAUS's Avatar
it prpbally is but is your 70mm MAF calibrated to the 30lb injectors???
HAUS is offline
Old 03-11-2006, 02:15 PM
89chatofive0
89chatofive0's Avatar
ORIGINAL: MattyHopper
A floating valve is when the valve stays open, not long but it stays open, if this where the case though i think you would have some internal damage since the piiston would hit the valce when it comes back up, then the car would run crappy throughout acceleration
89chatofive0 is offline
Quick Reply: Car not making power after 3/4 throttle
