Trick Flow -vs- GT40 package
ok if you had to pick one of these combo's which would you pick and why? also ... if you wanted to change it a bit what would you modify?
option one: TrickFlow -> TrickFlow Twisted Wedge Heads, TrickFlow Track Heat intake, TrickFlow TFS-51402001 cam
or
option two GT40 -> GT40X Heads, GT-40 intake, B303 cam
or
RE: Trick Flow -vs- GT40 package
i voted trick flow too, from what i've seen trick flow will put out better numbers than that GT-40 set-up... i wouldn't call it junk though, especially since that's the set-up i bought (not installed yet) but i got it for incredibly real cheap from a friend so the decision was obvious for me.
I'm in the same debate myself but by everyone else it looks like Trickflow is the way to go. (It rhymed) haha ha ha
But seriously, I think I would change one thing though and go with this intake instead of the Track heat.
Trick Flow "High Flow Intake"
You can't go wrong w/ the TFS top end kit. the twisted wedge heads are better flowing than the gt-40's and you don't have to worry about clearances. My vote went to trickflow....
ORIGINAL: FoxRod
It all comes down to what you have planned for your car. For a street car, the street heat intake will be okay, the track heat could be too, but it has shorter runners losing some low end tq, but giving you more hp up top at higher rpms. The box intake puts your power even higher in the rpm range than the track heat. I don't think you'd be able to rev high enough to use it w/ the top end kit.
