Kill Switch???
Kill Switch???
Ok. Got a pretty nice setup and worried about the city Im living in... Tacoma Washington. If u dont know has one of the highest crime rates in the nation, top 50. So im looking into installing a Kill switch. I am not sure at all how to do it. Not any ideas... So i need some... Please help
RE: Kill Switch???
ORIGINAL: eaturls1
I NOW WHAT UR TALKIN BOUT I LIVE IN BALTIMORE, MARYLAND THATS IN THE TOP TEN FOR CRIME RATE BUT U CAN ALWAYS JUST PULL THE COIL WIRE OFF UNTIL U GET SWITCH HOOKED UP OR PULL FUSE FOR FUEL PUMP OUT.
RE: Kill Switch???
ORIGINAL: turbostang21
you can also use a hidden switch for your fuel pump
RE: Kill Switch???
Kill switch is good.....i have two, one inside the car for my fuel pump and one under the hood for my battery...so they can't jump it or run it.........but usually if they want your car all they are going to do is back up and tow it......at least that's what they do in houston. it's pretty easy...line in and line out usually with a toggle switch as the relay to open or close the valve.
[IMG]local://upfiles/29046/964161A1DCE54CD5BB677B051CFB344F.jpg[/IMG]
Matt's 95 Stang
10-05-2015 07:16 AM
