85 GT wont start, help!
Hello all, new to the forums and ive been reading and it looks like there is a lot of expertise here, so i feel confident that my question will get answered
I've just replaced a bad mechanical fuel pump on my 85 GT, and true the car hasn't been started in about 8 months, but i get it to start only by holding the ignition all the way to 'start' and holding it there, released it to normal 'run' mode results in the engine dying and i get an awful clicking coming from behind the glove box on the pass. side. Im thinking solenoid or maybe a ignition relay or something.. but I thought id check here before i go out and start buying all sorts of parts down at checkers..
Thanks for the help!
RE: 85 GT wont start, help!
Not really a bad relay, if the ignition switch is kaput in the "On" position, it might not be sending the juice to the components/circuits it should, once you move it to the "Start" position, it then sends the juice where it's supposed to, or another way to see it would be...."On" position = "Off" for some components. GL
