Water pump help
03-08-2006, 04:46 PM
Water pump help
Hey everybody. I am installing a summit water pump on my 86 5.0. Are there any special tools or pullers required? Also how hard is it? Any tips, tricks, or run-throughs would be greatly appriciated.
03-08-2006, 04:51 PM
RE: Water pump help
i bought the chrome 1 from summit for my 88 and ther were no special tools need its fairly simple just make sure the gasket stays in place
03-08-2006, 04:53 PM
RE: Water pump help
oh yeah make sure you drain the coolant hehe and if its old replace with new and look at hoses for cracks or wear
03-08-2006, 05:00 PM
RE: Water pump help
Yea, and dont get the bolts mixed up. For some reason Ford though it would be a cool idea to make the bolts all different lengths
03-08-2006, 05:02 PM
RE: Water pump help
it should go on easy
03-08-2006, 05:04 PM
RE: Water pump help
^^ Agree... it should be cake work.
03-08-2006, 05:08 PM
RE: Water pump help
also when u take out the bolts bbe carefull they dont break on my 89 i twisted 1 bolt and snaped it = bad news, just take ur time.
RE: Water pump help
Rock on, Ill let you know how it went later tonight.
03-08-2006, 05:10 PM
RE: Water pump help
the job is easy i installed a summit racing pump just last month in my 95 302 you may have to jack the front end up for those tight bolts and also if its the factory pump from back in 86 and the pump's been leaking for awhile the bolts ford installed sucked and may have rusted in place and will be a bitch to get completly out may need a hand torch to loosen them up but if not easy 30- 60 min. project good luck
03-08-2006, 05:24 PM
RE: Water pump help
It took me roughly 30 minutes to change mine. Put sealant on the block side and put the gasket on the block first so it doesn't move while your mounting the water pump, its a very easy project, shouldn't take long at all.
