Maf question
RE: Maf question
ORIGINAL: Tims 88GT
because I run a 70mm tb and a stock maf right now, I lost a good bit of top end which I expected...
RE: Maf question
ya killin me man, ya killin me! i have 75mm tb and 75mm maf meter calib. for 24lb. i think i should go 80 or maybe 76mm maf. i dont think the same size is good either do you? and about the bikini contest. those chicks need to lose the zeros and get with the heros.[sm=smiley20.gif]
ORIGINAL: Tims 88GT
lol come on I hate the show, except for the one part im sure you know what part im talking about bikini contest lol. I guess I need to go to the local auto parts and get a Johnson rod to lol
RE: Maf question
sry but not to be an *** but it seams no one ever reads the whole post. im asking about the maf being smaller than the TB. the TB has not changed. I swapped my 80 mm maf for my stocker because the 24's I had in the motor were to much. so as I say again will a maf that is smaller than the TB hurt performance. because I have hesitation problems, and I lost top end after I put the stock maf on, in theory this is true because you are restricting the incoming air. but I can not figure out my low rpm hesitation.
RE: Maf question
HAHA I know why do they want to be with someone that runs 4 and 6 cyl when they can have a man that runs 8 or larger, I will say I like the sound of a 8cyl, I hate the sound of a 10 cyl, and I would do anything to listen to a 12 cyl everyday. I want a ferrari 575 maranello what a car.
RE: Maf question
I have a question I dunno if anyone can answer it but I figured I would ask. If you have a Maf that is to small aka smaller than your tb how will the motor react to it? because I run a 70mm tb and a stock maf right now, I lost a good bit of top end which I expected but my throttle response sucks ***** now
edit* I felt like you were kinda getting snappy, so I had to defend the guy
RE: Maf question
http://www.mustangworks.com/articles...tionBlues.html see if theres anything in there that can help. i couldnt understand it lol.. but its alot of info on how mafs work and problems they can cause. worth a try. good luck.
RE: Maf question
thanks ikeybmg. Marx91 my main problem is I have a low rpm hesitation, and my throttle response sucks now. I don't know if you saw my post the other day but I asked the same question and got 0 response. I think since the Maf is smaller than the TB the Maf is not letting enough air into the intake tube and the motor is sucking more air then the Maf can calibrate fuel for and that is giving me my hesitation. I dunno that's why I asked. ricepatrol I did not ask a question in theory I stated it.
