UNDERDRIVE PULLEYS INSTALLED NOW CHARGING PROBLEM
#21
RE: UNDERDRIVE PULLEYS INSTALLED NOW CHARGING PROBLEM
I installed them on my 88 gt and had stalling problems. It wouldn't keep a charge. Whenever i was idling i had to keep giving it gas to keep my battery charged. I bought a new battery and the problem was fixed. If your battery is old, that could be your problem. If you have an aftermarket stereo system that is drawing a lot of power, that will worsen any charging problem. If nothing else works you'll have to buy a bigger alternator (not expensive)
[IMG]local://upfiles/25786/8F418836B14449E19C10F45834671F5C.jpg[/IMG]
#22
mine is crappy as hell at idle once i start cruising it's okay but i don't have the heater in it yet or a radio. i'm thinking about installing dual batter set up
#24
well i'm runing a electric fuel pump dual fans, and when ever i get the insides done i'm runing a jl w0 12 in a bandpass box and all aftermarket speakers i run dual jls in the camaro and when it hits real hard the voltmeter drops from 16 to like 12 i put a capsitor on it and it dosn't drop as bad.
#28
i really want to take the system out of this car because stangs are hard to get loud.My set up would be alot louder in a diff car.If you all a looking for a good alt try ohio generators or stinger electronics they got some nice 200 amp alts. stinger alts come powder coated and the ohio looks stock but has better performance than the stinger
DrunknRuckus
08-23-2015 10:05 AM
