5SPD swap, wiring question
I need to know where the wires are that plug into the pedal assembly are on a 92 GT. The car had an auto in it and I would assume that the wires are there somewhere. Also, what do I need to do with the wiring that goes to the t-5 transmission. I think the harnesses are different between the AOD and t-5. Thank you.
RE: 5SPD swap, wiring question
In the pedal assembly, there are 2 spots for 2 different harnesses to plug in. I need to know where those wires are located in the car.
On the t-5, there is a spot where a 3pin harness plugs in. The harness for the AOD is different. Do you know what I need to do in order to hook this up.
I'm under the impression that this harness is for reverse lights and I don't know what else.
cardsrus1
19
09-15-2015 08:37 AM
09-02-2015 08:40 PM
