gt40 vs gt40p
RE: gt40 vs gt40p
Not trying to be rude, but do a search. I know this has been covered several times in the past 2 weeks or so. Check this out too....
http://www.themustang-net.com/tech_articles/gt40p.shtml
RE: gt40 vs gt40p
Im not trying to be rude, but you didnt even answer his question...He had a 2 part question, so youve helped him with the first, now its time for the pro the answer the second part...
Yes the p would be better than the regular cast gt-40, this is best for a N/A fox. I personally would have the heads P&P, they will flow better.
RE: gt40 vs gt40p
Actually, the link I posted does answer both of his questions.
Stangstang--are you on a budget? If so then you're headed in the right direction as far as heads go. If not, then look at some twisted wedge's or AFR 165's.
RE: gt40 vs gt40p
gspfunk- it just seem like your being a dick...but I felt the like didnt have any info weather the P's would be good on a N/a fox....If your on a budget you can build a cheap 12 sec stang with The P heads, TFS cam, eddy intake mani, and 4.10's and slick 12's easy, if your on a budget...Or you could get your stock heads P/P from thumper and be 12's that way...
RE: gt40 vs gt40p
Sorry if it came across that way, that wasn't my intention. I just figured since it's been covered recently, it wouldn't be very difficult to find the previous posts instead of everyone repeating themselves.
Here's another link I found useful:
http://www.allfordmustangs.com/Detailed/630.shtml
