How about your car?
How about your car?
I was just curious what kind of oil pressure you guys get when your motor is hot? My car starts out at about 45 to 50 PSI at idle when cold but when it's warm it runs 25 to 30 PSI while cruising at 2000 rpm and as low as 9 or 10 PSi at idle? How low is too low? Thanks
RE: How about your car?
Not real sure about Ford specs but Dodge is like min 8 psi at idle while hot.
Might start considering looking into this. I would poop my pants if i seen oil pressure at or below 10 psi personally.
no im pulling your leg bro, you will loose a single psi at max. because you run oil through the sc to keep it running (free spinning) and that is more heat, heat thins out oil. but like i said nothing to worry about. just making you think a lol
