lower control arm question
Of these which is best that you've all found?
Maximum Motorsports Standard Lower's
Maximum Motorsports Adjustable Lower's
Mega-Bite Jr's
Or just box the stock lowers (i doubt that does much)
Mega-Bite Jr's
RE: lower control arm question
i have about 300rwhp and i have absoblutely NO traction. I have 100% stock suspension except for the lowering springs that came with my car. Im taking them off and getting drag springs. I want straight line performance. I dont need anything radical just enough to get my car hooked up and stop spinning so much.
do i really need adjustable lowers? i mean im not getting seriously into racing. im wanting traction more or less for street. The only reason i can see needing adjustable's is to fit bigger tires under the wheel wells.
Get some shocks/struts that will compliment your springs, too. Stockers don't have the right compression/rebound rates for aftermarket springs.
You can go w/ adjustables if you want to, but they aren't a necessity. But, if you decide you want to try some bigger tires later, you'll have to spend the extra $ to do so. Subs and a strut tower brace will stiffen up your chassis pretty significantly.
The main thing im wondering is, do the adjustable control arms give you better traction than the standrads?
I dont see how unless you just used a larger diameter tire with them.
What about uppers? Just stay stock unless im going for all out racing.
