dont know what happend
RE: dont know what happend
no i adjusted it cause it was sitting at 50 psi. and i know thats too high for a N/A 5 liter with 24lb injectors.
well i went out and checked every spark plug and they all look identical and none of them looked bad. but after doing that it started running a little worse. seems like every time i try to fix something with it, it just makes the situation worse. hell now at idle the engine has even started knocking, and its running hot again
do you have a 3G alt. conversion? Cause if you dont with a electric fan it does that. I chased a mis-fire for like 4 months, turned out the alt was going out the whole time. Finally replaced it with a 3G and everything was fine again. Headlights were brighter, etc.
yeah i have a 3g alt, its about 3 weeks old. I did adjust the FP back up about half of what i took it down, and it didnt change at all. Im just kind of out of ideas now....i really dont know what the knocking its doing is about either....
i really doubt its a burnt valve, ive put about 50 miles on it since this all started...its not knocking today either. Im almost wondering if its a clogged injector. since this did start happening after i changed the fuel filter, im wondering if i accidently got some dirt in the clean side of the filter or fuel line.
