Tune up
RE: Tune up
alright here goes....autolite or bosch plugs are prolly the best....taylor or ford wires are great...get an msd cap and rotor if you can afford it....replace fuel filter....change out fluids for royal purple,oil,rearend,tranny....air filter go k@n and if you have one already clean and recharge it. then you should be ok. you dont have to use the brands i named but i would recommend doing all of the above.
RE: Tune up
depends how much your looking to spend. if you wanna really good tuneup and have the money go with complete msd. coil, wires, cap rotor. and go with autolite platinum or double plat. if you cant go with MSD, then go with accell. ford racing wires = pos, alot of people will tell you that. change your oil(pennzoil or mobil) 2 best oils, change your fuel filter(wix, 2nd choice = microguard). oh and change your oil filter too, clean your air filter(if you have a re-usable one like k&n). when you fill up use 93 octane and get lucas octane booster & fuel injector cleaner) give your whole fuel system a good cleaning. other then that i cant think of anything atm.
RE: Tune up
tell you what, royal purple was a waste of money for me. 6 bucks a quart. Any petrolium approved oil will do you just fine. Dont recommend full synthetic, if you want to go that route go with a synthetic blend
RE: Tune up
are you talking about the motor oil or all the fluids they make? i changed all mine and i really can tell no power increases like they say and i believe thats bullshizz anyways. but it does make my tranny feel smoother and i know that my rearend was getting really hot and thats one reason i changed it out and its running cooler now so i dont know about the oil but there other fluids are killer.
RE: Tune up
i just know in general pennzoil and mobil are 2 of your best oils besides the synthetic stuff which is like $8 a quart. i need to figure out why my car is shifting so hard, it shifts nice all the way till it goes in OD, once it goes into OD it basically slams into it, feels like & sounds like i ran over a branch on my rear tires. i just serviced the tranny too. changed the transmission filter & fluid. well a shop did it for me, because i had a cast on my wrist.
