How to tell what gears
RE: How to tell what gears
A way you can get a close idea without opening up the rear is to take a piece of chalk and make a mark on the drive shaftstraight down, then then make a mark on one of the tires straight down. then put hte car in neutral when it is jaked up. spin the tire and count number of time the driveshaft spins for 1 full tire rotation. Say you have 3.55 the drive shaft will spin 3 1/2 times, if you have 4.10 the driveshaft would spin a bit over 4 times.
-Jared
-Jared
i have a 94 cobra, and the tag on my stock rearend dosnt say my ratio, it has a bunch of numbers and leters. i looked in my service manual and it says look under the ax code in ur door sil.
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
