Convert limited slip to posi??
Hi guys New here and learning alot I have a 90 mustang with 373 limited sip or open rear and want to convert it to a posi what do I need to change and buy to do this thanks for the help Chris
RE: Convert limited slip to posi??
You could weld the spider gears up but i wouldnt.Do as he said and get yourself a locker.
We weld up the spider gears on the stock cars since they rarely come out of second gear around the dirt track.But i would not do that on a street car.
one why you want to upgrade from a tractionloc[limitedslip] to a posi. both do the same but the posi is little stronger. running spools and lockers on the street suck. if your tractionloc is peg legging it. you can get a rebuild kit for it. to replace the clutches in it. to make it plant 2 tires on the straightaways.
why dont you just get a spool ..dont know why ,unless your track all the time try pushinhg your car 180 deg the a spool an you 'll know what i mean,,,,,if you got a new limited slip,,itr would be just like posi,,..you could still turn,,
ORIGINAL: SpeedRicer
i agree w/ohsoquik, what's the point? have you ever driven posi on the street? no fun...keep the limited slip.
Are you saying its no fun because it gets full traction and you cant spin them easy or what ?
I also Have a 55 Chevy I have a posi in that .I drive that on the street all the time and have no problems with it The only time I notice it is when I am pulling out of stop streets or parking lots making a left or a right and I get a little hop or chirpping from the tires skipping on the roadway
