speedometer w/gear change
Old 02-22-2004, 10:38 PM
af41
af41's Avatar
Default speedometer w/gear change
I recently had 3.73s put in my 94 cobra. I also changed the speedo gear to adjust my speedometer, but it still seems off. Someone told me it will still be about 5% off. Is this true? Is there any way to correct it? The speedo gear was bought through Ford Motorsports so I'm assuming it's the correct gear. The speedo still seems about 5 mph or so off. Any suggestions?
af41 is offline
Old 02-22-2004, 10:41 PM
mkspeed26
mkspeed26's Avatar
Default RE: speedometer w/gear change
you can calculate your speed at a given rpm and wheel size and then check to see how close it is.....
mkspeed26 is offline
Old 02-22-2004, 11:04 PM
af41
af41's Avatar
How do I do that? I always heard 3.73s ran at about 2500 rpm @ 80mph. My speedo reads 85-86 mph @ 2500 rpm. I guess I'll have to pace someone next to me. I also heard having the car dynotuned will eliminate the problem. Is this true? I still want to get AFR heads and a different cam so I want to hold off on the dynotune.....
af41 is offline
Old 02-23-2004, 01:18 AM
hotrodman
I ♥ Acer
hotrodman's Avatar
you got a cable???? or electonic????
hotrodman is offline
Old 02-23-2004, 10:24 AM
Quik
Quik's Avatar
on a stick car there is 2 gears that need replaced. an auto has one gear to replace. the stick has a driven and drive gear. the auto has a driven gear. for your speedo to be on you need the correct tire size also. the speedo gears are calculated for the overall size of your wheels along with your rear gears and tranny gears
Quik is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Dathan
10-05-2015 05:52 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
lmurf60
09-24-2015 10:07 PM
Quick Reply: speedometer w/gear change
