94 GT -- Mod Suggestions???
Old 03-14-2006, 09:46 PM
203Mach1ne
203Mach1ne's Avatar
Default 94 GT -- Mod Suggestions???
I have a 5.0L 1994 Mustang GT Convertible
I have a full exhaust already put on, but I want more speed/horsepower/performance.
I'm putting a Cold Air Intake and 3.73 Rear Gears w/ new motive bearings on soon...
Also a Pro 5.0 Shifter, King Cobra Clutch, and SprangZ Lowering Springs...
Any other suggestions for a speedy daily driver???
203Mach1ne is offline
Old 03-14-2006, 09:53 PM
gspfunk
gspfunk's Avatar
Default RE: 94 GT -- Mod Suggestions???
A larger MAF w/ your CAI, and then suspension and chassis stiffening. I would get new shocks/struts w/ those springs b/c the stock valving will make your ride rough if the suspension components don't compliment each other.
Then subframes and a strut tower brace.
gspfunk is offline
Old 03-14-2006, 09:54 PM
95gt302
95gt302's Avatar
throtle body
95gt302 is offline
Old 03-15-2006, 07:52 PM
203Mach1ne
203Mach1ne's Avatar
When you list suggested mods can you give me an estimated price and estimated performance boosts please, because I'm not too familiar with them...
I'd really appreciate it!
Are Carbon Fiber hoods a waste of money? I'd like to lighten up the car, but I'm not sure how much the stock hood weighs in comparison to a carbon fiber hood...and theyre quite expensive! I love the hoods on the 99-04 mustangs, is theyre any way I can put one of those on my 94?
Old 03-15-2006, 07:54 PM
Mustang5.0_GT
Mustang5.0_GT's Avatar
Well ... How much Money do you have to work with ?
Mustang5.0_GT is offline
Old 03-15-2006, 07:55 PM
Crazyfast50stang
Crazyfast50stang's Avatar
No carbon fiber will lighten up your car a good amount. I have driven with 5 cases of oil in my trunk and it feels like im dragging around a lot of weight and then when I took it out it felt awesome. Do you have a 5 spd or auto? But like mentioned earlier 65mm throttle body, 73mm MAF, some upper and lower control arms with some subframe conectors, a CAI and UD pulleys, all that will make your day brighter.
Crazyfast50stang is offline
Old 03-15-2006, 08:05 PM
203Mach1ne
203Mach1ne's Avatar
Its a 5 speed V8 5.0L GT Convertible
After I put the mods I listed at the beggining (only around $800) I'll have about $1500 more that I can put into the car...
Old 03-15-2006, 08:13 PM
Crazyfast50stang
then yeah work some suspesnion and do what was mentioned. Later on get an upper and lower intake manifold or just save up and get some AFR 185 heads.
Old 03-15-2006, 11:32 PM
gspfunk
gspfunk's Avatar
Tokico shock/struts = $290 --will work w/ those springs for better ride.
75mm MAF = $125 on ebay --10-15hp and more airflow
U/L control arms = 159 @ jdsperformance.com -get more power to the ground and get rid of stock quad shocks.
MM chassis brace kit = $350 --xl subframes, strut tower brace, K member brace--will make your chassis much stiffer
U/L intake = $200-400 ebay --TFS street heat, RPM, Cobra.... --15-20hp
Heads = $1000-1350 new --Twisted wedge, AFR 165...--50-70hp
Carbon fiber hoods are lighter and stronger than fiberglass, but you've gotta get it painted so you don't look like a ricer.
gspfunk is offline
Old 03-16-2006, 04:02 PM
203Mach1ne
203Mach1ne's Avatar
The U/L control arms....
How do they get more power to the ground, and how much more would I be getting there..?
Quick Reply: 94 GT -- Mod Suggestions???
