lashing
RE: lashing
well i found an article on how to put them on and wut not..and i did as they said and torqued them down BUT there is still a space between the arm and the valve stem.....??? do i need long push rods
RE: lashing
Are your lifters pumped up? Is you intake off? If it is look to see if the plunger inside the lifter is up to the snap ring when you loosen you RR, it needs to be to get started right.
RE: lashing
yes the intake is off and and the lifters to the top and there was still like .125" of a gap .....the heads r completely stock...and it kinda pissed me off but owell ..new pushrods will b here in the morning
