fox vs sn-95 5.0
#21
RE: fox vs sn-95 5.0
ORIGINAL: SPE926
all hp ratings are taken from the rear wheels, the 96-98 4.6 is deffintily slower than the 5.0's and the later 4.6's
#22
ORIGINAL: SPE926
#23
1995 COBRA
1995 COBRA R
ENGINE
Type 90° V-8 90° V-8
Bore x stroke 4.0 in. x 3.0 in. 4.0 in. x 3.0 in.
Displacement: 5.0 liter/302 cid 5.8 liter/351 cid
Compression ratio: 9.0:1 9.0:1
Horsepower: 240 hp @ 4800 rpm 300 hp @ 4800 rpm
Torque: 285 lbs.-ft. @ 4000 rpm 365 lbs.-ft. @ 3750 rpm
SUSPENSION
FRONT: Modified MacPherson strut type with separate spring on lower arm, 400 lbs./in. linear-rate coil springs, 25mm stabilizer bar Modified MacPherson strut with separate spring on lower arm, 700/850 lbs./in. progressive-rate coil springs, adjustable Koniâ„¢ struts, front-strut tower brace, 30mm stabilizer bar
REAR: Rigid axle, four trailing links, two leading hydraulic links, 160 lbs./in. linear-rate coil springs, 27mm stabilizer bar Rigid axle, four trailing links, adjustable vertical shock absorbers and horizontal axle dampers, 200/260 lbs./in. progressive-rate coil springs, 27mm stabilizer bar
BRAKES
FRONT: 13 in. vented disc 13 in. vented cast iron disc, twin-piston caliper
REAR: 11.65 in. vented disc
11.65 in. vented cast iron disc, single-piston caliper
ABS: Power assist, four-wheel brakes with anti-lock
Power four-wheel disc brakes with anti-lock
WHEELS AND TIRES
WHEELS: 17 x 8 in. 5-spoke cast aluminum 17 x 9 in. 5-spoke cast aluminum
TIRES: Goodyearâ„¢ Eagle GS-C, P255/45ZR-17 BFGoodrichâ„¢ Comp T/A ZR P255/45ZR-17
PERFORMANCE
0-60 mph: 6.3 seconds 5.4 seconds
Top Speed: 140 mph
(electronically limited) 152 mph
PRODUCTION NUMBERS
Cobra Coupe: Black 1433; White 1125; Red 1447; TOTAL: 4005
Cobra Convertible: TOTAL: 1003 White 250; TOTAL: 250
1995 COBRA R
ENGINE
SUSPENSION
BRAKES
WHEELS AND TIRES
PERFORMANCE
Top Speed: 140 mph
PRODUCTION NUMBERS
#25
are yall sure the 94-98 were all the same? i thought the 94-95 had 225 and the 96-98 had 215. the cobra in 96-98 is also an sn95 right? 305 hp makes the sn95 faster than the fox..lol, technically
#26
the 96-98 is still an SN95, but it was the first of the 2V 4.6's. the cobra had the 4V heads, that's why it's 300hp for those years. the 2V was a pig. MM&FF is having a helluva time getting Project red headed step child to 300RWHP w/o the PI head swap.
#27
Here, I tried to seperate them out to make it a little easier to follow....
ORIGINAL: Mustang95
1995 COBRA
1995 COBRA R
ENGINE
SUSPENSION
REAR: Rigid axle, four trailing links, two leading hydraulic links, 160 lbs./in. linear-rate coil springs, 27mm stabilizer bar Rigid axle, four trailing links, adjustable vertical shock absorbers and horizontal axle dampers, 200/260 lbs./in. progressive-rate coil springs, 27mm stabilizer bar BRAKES
WHEELS AND TIRES
WHEELS: 17 x 8 in. 5-spoke cast aluminum 17 x 9 in. 5-spoke cast aluminum TIRES: Goodyearâ„¢ Eagle GS-C, P255/45ZR-17 BFGoodrichâ„¢ Comp T/A ZR P255/45ZR-17
PERFORMANCE
Top Speed: 140 mph
PRODUCTION NUMBERS
1995 COBRA
1995 COBRA R
ENGINE
SUSPENSION
WHEELS AND TIRES
PERFORMANCE
Top Speed: 140 mph
PRODUCTION NUMBERS
#29
ORIGINAL: 4eyedfreak
I know for a fact that my dads 95 cobra had a 351 in it, did the only make some with the 351 and some with the 302?
87-93 all had 225hp but in 93 they went to rwhp. sn95's made about the same power, but weigh about 400lbs. more than that of a fox GT. They used the same t-5 tranny, but their computers are different and it doesn't take as well to mods as the fox's do. same 8.8" rear, same WC t-5 tranny, and the same H.O 302 (aside from the intake & comp) that has redefined the world of performance, and is still doing it today. Got to love our cars!
