Air Silencer?
RE: Air Silencer?
The air silencer is a rubber piece that connects to the air box that surrounds your air filter. It goes from the box to inside the fender. Pull up your air box, if it's still there, and you'll see the rubber piece. If the air box has been removed then the air silencer will have been removed as well. If you don't see the rubber piece then someone has already removed it...this is most likely the case.
daltron
04-28-2016 08:10 PM
