Any ideas for an over rich condition??
My buddy has a 1986 5.0 (speed density) that he recently aquired and knows nothing about the history of the car.
The engine looks to be stock (with orange 19 lb injectors), but it has a Crane cam installed (according to the sticker on the core support), somewhat lumpy cam and sounds good.
The problem: it runs WAY too rich..... lots of black smoke out the exhaust.... all the time, idle, 2000 RPM, 3500 RPM it still smokes. It sounds and smokes like any carbureted car with a stuck choke!
We put in new plugs and O2 sensors... no change. I checked the fuel pressure.... it's right at 39-40 psi.
Does anyone have any ideas or suggestions???????
Thanks in advance!!!!!
RE: Any ideas for an over rich condition??
First....SD systems + a lumpy cam = A/F on the rich side....not a good combo. [sm=badidea.gif]
You might want to check if there is something else that might be causing the A/F to get that rich (MAP & EGR comes to mind), to be sure that's the case, suggest you check the system for codes running a KOEO/KOER self-tests and post back the codes you get. Hope this helps.
it would be blue smoke if it was the pcv valve. Zach hit that one right on the head, thats the problem. because the map sensor adjust the fuel to the vaccum/load on a sd car. it is going to give it a lot of fuel because it wants it to idle smooth and about 20hg in vaccum. the best thing to do is set the idle so it smooths out, it may be 1200-1400 rpm depending on how wild the cam is. and then reset the computer. that should help.
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
treesloth
09-28-2015 07:03 AM
