little bit of a problem...
Old 03-19-2006, 06:49 PM
gspfunk
gspfunk's Avatar
Default RE: little bit of a problem...
Is your intake stock? On the 94-95's you should have an elbow adapter or your intake should have one molded into it....
gspfunk is offline
Old 03-19-2006, 06:50 PM
grabbem88
grabbem88's Avatar
^^^thank you i almost forgot about that....if you don't have one it won't fit.
grabbem88 is offline
Old 03-19-2006, 06:52 PM
Tims 88GT
Tims 88GT's Avatar
he has a link for the elbow
Tims 88GT is offline
Old 03-19-2006, 07:01 PM
grabbem88
grabbem88's Avatar
^ ok i was lazy...that elbo fit's only one way right?....try putting the t-body on first?on the elbow
Old 03-19-2006, 07:03 PM
Tims 88GT
Tims 88GT's Avatar
yea it only goes one way
Old 03-19-2006, 07:19 PM
ZachW04Stang
ZachW04Stang's Avatar
I think you need to have an after market intake and an elbow adaptor to install it. Someone correct me if I'm wrong.
ZachW04Stang is offline
Old 03-19-2006, 07:27 PM
ikeybmg
ikeybmg's Avatar
if the intake is stock you need a tb spacer, if its aftermarket you need the elbow. the stock intake on 94-95 has the elbow built in. the tb spacer has the right pattern to fit it. its like an adapter.
ikeybmg is offline
Old 03-19-2006, 07:29 PM
Tims 88GT
Tims 88GT's Avatar
^^ bingo that the answer
Old 03-19-2006, 08:34 PM
ReVz
ReVz's Avatar
there is no elbow is the piece above in the link the elbow i would need for this thing to work
ReVz is offline
Old 03-19-2006, 08:36 PM
Tims 88GT
Tims 88GT's Avatar
yep
Quick Reply: little bit of a problem...
