ring & pinion gear q?
RE: ring & pinion gear q?
Does not come with speedo gear. First off you need to know what gear is in your tranny, 7 or 8 tooth. I have a 7 tooth gear in my trans with 3.55's in the rear I need to go up from the 19 tooth (stock) to the 23 tooth gear, I'm on a 6 month waiting list through Ford though I know I can get them other places, i won't wait 6 months.
http://www.latemodelrestoration.com/...LINE~MSPEEDCOR
You're gonna need the white one about 5 down if you have the 7 tooth gear in your trans.
With a 28 tooth gear you will just screw up the gears in a hurry, the most you can possibly go with the 7 tooth, assuming that's what it is, is 23, otherwise I would be getting a 24 or 25 tooth gear for mine. I'm also going to be changing the speedo drive gear soon enough anyway, I'm going to put a 6 tooth drive gear then 21 tooth spedo gear is 3.5:1 so damn close for my my 3.55's
KingRando
10-02-2015 08:06 AM
