no oil pressure need help asap!!
#21
RE: no oil pressure need help asap!!
If you are sure the crank and bearings and oil pump are fine then You can check your oil pickup. It kind of works like a straw if it is damaged you wont get any suction and you will get terrible pressure. This isn't exactly common but can happen.....just an idea.
#22
the second i saw that it had no oil pressure i stoped driving it.
i cant imagin my bearings being bad since i only have 30 miles on it.
is there a way that you can pull the oil pan without removing the engine?
it has the trick flow stage I cam along with the twisted wedge heads and street heat intake
#24
I have a HAL K-member, stock pan, DSS windage tray, standard volume oil pump and I had to lift the engine about 4" to get my pan off.
#26
if you have an after market k member then you should beable to. if not then your gonna have to pull it un fortunely. kinda the same thing happend to me, i was driving and i started to hear a loud taping noise and no oil pressure, i thought it was either rod or main bearings but it turned out to be i broke my oil pump shaft. i know yours wasnt making any noises but your still gonna have to pull your engine
ccdguy
09-19-2015 05:20 PM
