Camshaft
Camshaft
I am buying a Cam for my Mustang this weekend, i plan on getting the Performance Z-Cam, in Jegs its only 169.99,would i need anything else when i install it? and if anybody has a after market cam in their Mustang tell me about it, i might change my mind before i buy one this weekend!
RE: Camshaft
ORIGINAL: ckyguy68
im not hijacking your thread, but do you have to pull the radiator when putting in a cam?
RE: Camshaft
You do not have to pull the motor out to install a cam in a Foxbody, if you run AC, it wont clear the condenser...you have to basically strip it down to a longblock..A Z-cam, is outragious for a Stock Engine, try something like a E-cam, and yes, you will hafto do a pretty good bit of valvetrain work to get the Z-cam to work...i myself dont think it would be worth, "just for the sound"=
korey
korey
RE: Camshaft
You don't have to pull the motor out of a Fox Body either. Here are the specs on that cam:
Duration: 228°/228° @ .050'
Lift: .552'/.552'
Trans: 5-Speed
Notes: Fair Idle, Excellent Torque & Power To 6,500 RPM, Check Piston-to-Valve Clearances,
Requires Spring Pressures 340psi Open/120psi Close
The duration isn't that bad but the lift is to big for a stock motor. I personally would go with the E303 instead.
Lift: .552'/.552'
Trans: 5-Speed
