One Wheel peal
One Wheel peal
So my friends wanted me to do a burnout the other day, So i powerbraked it, and about 3 seconds later I see all the smoke (thinking it was really good.)
Well only one wheel spun.
quote from my friends "the right wheel was f*cking cookin', but the left one didn't even chirp."
so is this supposed to happen or is there something wrong with my rearend?
RE: One Wheel peal
yeah, cheap to rebuild the traction lock.
if only one is spinning that means your stock t-lock ( ford's posi )
is not locking up like it should.
Think it uses a series a clutch disc to lock-up
might want to consider upgrading to an Eaton for a little more money
RE: One Wheel peal
i agreee, mine is starting to slip some too. the clutches wear out inside. im going to get the setup sc94gt is talking about, and go from 3:73 to 3:90 gears for a little more umph!
ORIGINAL: sc94gt
Don't bother with Ford's Trac Lock... upgrade to Eaton's carbon disc setup and get some 31 spline axels.
It'll handle quite a bit of punishment.
