Starting Problem..Help
RE: Starting Problem..Help
sounds like your fuel is bleeding back to tank ..try this turnyour key on and off a few times/priming the pump...if it starts right up
chase the fuel system...if not start with your distributor.
i had ther same problem before and only thing i could do to get it started right there on the spot was to pump the gas pedal and it started up.
did you notice your check engine light coming on for anything?
yes i do notice a check engine light comming on. do you think it would throw any codes or anything? i dont want to take it to a shop or anything, cuz i dont have the money with these outragous gas prices.
so how did you fix it?
i forgot to add these to the PM.
http://www.mustangworks.com/articles...-iv_codes.html
http://www.troublecodes.net/Ford/
