Starting Problem..Help
#21
RE: Starting Problem..Help
warm/hot starts only... knock on wood
its really agrivating me. becuase i dont want to pull up to the gas station to pump gas, and have it not start.. not taht i want to pull up to the gas station period[:'(]
#22
yeah i forgot to add in the pm that when i was having intermittent fuel and spark problems it was very rare and occasional at first. over the next year and a half it just gradually got worse until it was happening every time it was warm. towards the end of the PCM's demise, i was also stalling while the car was stopped in drive. and sometimes at wide open throttle it would misfire. good luck once again.
#24
on a hot day, after sitting through a lot of traffic, my ignition module will heat up and my car will sputter and die. Remove the module, and grease the back with dielectric grease and place it back. It might help, but if it continues, replace the module
#26
well i wasnt getting any reply's until last night, and ive been at work all day(and dont get off for another hour) so ive jsut been collecting info for tomorrow, thats when i plan on tryin stuff. might go buy a code reader from autozone.
#27
don't by a code reader just use a jumper wire,and use it on your harness output...where you hook up the code reader..just read flashes,and count.
you can do KOEO,AND KOER...
PLUS IF IT'S YOUR MODULE WHICH I THINK IT IS..whoops....i have a MSD one...they ain't cheap but i'll sell it for like 35-40 bucks?..
#28
ORIGINAL: grabbem88
#29
well the problem is getting worse. it happened while i was driving the other day. i dont kno what to do. im gonna go try this make shift code reader, but i cant drive my car until i get the problem fixed. but idk if its fixed, because it does it 100% randomly.
dalefrancis88
09-11-2015 07:15 AM
