valve covers
valve covers
so i know you can fit 1.7 RR under stock valve covers by taking off the baffle but i was wondering if you can fit them under fords "mustang, powered by ford" valve cover
these ones
[IMG]local://upfiles/18077/15CC8FB532354F9D999ACC81CAADF954.jpg[/IMG]
these ones
RE: valve covers
Unless those are tall covers, you'll probably have to grind the baffles out of them. Another trick I learned is to get the rubber (metal ring inside) valve cover gaskets and use 2 on each side. It gives you more clearance.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
