Signs of a bad fuel pump?
Im thinking about just replacing my fuel pump due to my current situation. read this
what are some signs of a bad fuel pump?
whats a good size? my engine is 99.9% stock, and i plan on a engine swap this summer. i will be using the same stock 19lb injectors. will a 255 be too much, or would a 190 work?
RE: Signs of a bad fuel pump?
ORIGINAL: ben5.0
well i plan on either a 351w, 331, or a 306.... i just need to kno if my current one is going bad due to my problem..(the thread link)
if you think its bad fuel pump turn the key to the on position where you radio comes on but done crank it so the pump turns on do that like 2 or 3 times then crank it if it starts that way you need a new pump i had the same problem
TfcCDR
09-14-2015 12:08 PM
