t-5 swap
RE: t-5 swap
in my experience with swaping, it wasnt bad, but i dont know about doing it in a weekend if you never done something like that. i went from a t-5 to a C4. only mods i had to do was cutting loose the crossmember support where its welded on each side. you then can slide it back so you can bolt your trans mount on. used the same driveshaft, exhaust was fine. what you get into is running cooler lines from the trans to the cooler up front, mounting a shifter, taking off the clutch pedal (dont have to), cutting hole for shifter cable. it sounds like a lot i guess, but really its not to bad.
Matt's 95 Stang
10-05-2015 07:16 AM
