Aftermarket speedometer calibration
Old 03-02-2004, 05:38 PM
Musthang
Musthang's Avatar
Default Aftermarket speedometer calibration
Factory 1991 GT speedometer to a 200MPH speedometer. How do I calibrate?
Musthang is offline
Old 03-02-2004, 06:02 PM
bmorrisj
bmorrisj's Avatar
Default RE: Aftermarket speedometer calibration
get a new speedo gear...
bmorrisj is offline
Old 03-02-2004, 06:07 PM
Musthang
Musthang's Avatar
Never had to mess with the speedo gear. What am I setting my self up for? Big task?
Musthang is offline
Old 03-02-2004, 06:16 PM
bmorrisj
bmorrisj's Avatar
not really, just follow the speedo cable from the cluster to the tranny, its the cable on the drivers side of the tranny, pop that off and change the gear, i dont know what color you need tho.... 20 minute job... i dont know about AOD's it might be the same...
bmorrisj is offline
Old 03-02-2004, 06:20 PM
Musthang
Musthang's Avatar
Thanks! How do I find out what color I need for a 200 MPH?
Musthang is offline
Old 03-02-2004, 06:28 PM
bmorrisj
bmorrisj's Avatar
what rear end gears do you have... if you have stock gears i think you need a red gear...
bmorrisj is offline
Old 03-02-2004, 06:31 PM
Musthang
Musthang's Avatar
Stock, 2.42 not sure.
Musthang is offline
Old 03-02-2004, 07:11 PM
bmorrisj
bmorrisj's Avatar
look in you driver door sticker, (inside edge of the door) and look at the code for AX, you probably have 3.08 or 2.73...
bmorrisj is offline
Old 03-02-2004, 07:15 PM
Musthang
Musthang's Avatar
My problem is the guy that put the new speedo in left the stock gear so the dam thing reads 80MPH at 65 or so.
Musthang is offline
Old 03-02-2004, 10:59 PM
VertStangGT86
VertStangGT86's Avatar
the 200mph speedos that I've seen don't need any calibration, as long as they gave you the one for your year it should be already set up for the stock gearing and speedo gear. Call whoever you bought it from and check with them.
VertStangGT86 is offline
Quick Reply: Aftermarket speedometer calibration
