why is my car so slow?
RE: why is my car so slow?
ORIGINAL: mj88stang
if i'm lean would a 650 doublepumper do the trick?i've been told a bigger carb will help the top end but not much for my launch and bog problem
I don't think you *need* a 650DP, I think yours could be tuned to work fine.
you shouldnt have gotten the street avenger you should have gone with a 600cfm vacuum secondaries like mine when i went to the speed shop and told the owner/machanic i wanted a street avenger he almost kicked me out of the store
[IMG]local://upfiles/28839/630B96A10ABF46998AAC312DCF92445B.jpg[/IMG]
[IMG]local://upfiles/28839/BE7A8E1C96594CC8B18A0FD28BBCFDEE.jpg[/IMG]
ORIGINAL: mj88stang
ORIGINAL: HACKGT350
the carb isn't box stock, the accel pump has been upgraded from 30 to 60 cc, main jets went from 54 to 58 and primary squirter is also bigger than stock but i don't remember what i think it is a 20 something, the cam is a b303 ford hyd roller with trick flow spring and retainer kit and 1.6 roller rockers
2200stall is worthless. it might as well be stock. look into something in the 3000-3200 range. try http://edgeracingconverters.com/
