88mm MAF w/ 75mm TB with 29lb injectors?
Hey would a 88mm MAF and a 75mm TB work well with a 306 w/ GT40P heads and trick flow intake? I was told that 90mm is to big, is 88mm to large for my car? Also do you have to change your computer computer if you want to run different injectors, or just change the maf. Any info would be appreciated. Thanks
RE: 88mm MAF w/ 75mm TB with 29lb injectors?
65 on a mild motor is just enough an that is what I would recommend for you. To much of the air rush on a motor like that will cause delays in throttle response. Your letting more air into the engine then it needs. 65mm or 70mm. And you dont need to change the computer you need to get a MAF That is calibrated for the injectors. Upgrade your injectors when you get the full H/C/I
No I was asking because if your just doing the H/C/I which is what it sounded like in the begining then it was just extra money and I also wanted to knwo if you were putting a blower, turbo, or NOS cause you will need different injectors. If you are planning a project go for the gold so that you dont have to tear things down later.
