need help quick
need help quick
ok so the bushing on my front sway bar is toast and when ever i hit a bump the swaybar clucnks around. is it ok to take my sway bar completely off? i have hered of guys doing this at the strip to get better launches.will doing this hurt anything other then my handling.
RE: need help quick
Sway bars help to decrease body roll around corners. If you get rid of the sway bar your car will feel really loose around corners and you may even notice the body leaning more. Just go to Pep Boys and get the urethane bushings they sell for like $10 bucks.
RE: need help quick
ok so i went up to auto zone to buy the new bushings and when it came up on the cpu it needed to know the diameter of the bar. and there was 4 diff diameters to pick from. does anyone know what the diameter of a stock 1990 gt sway bar. if not how should i measure it. also can anyone tell me what number fuse the radio and interior lights run through. they stopped working and i think the fuse is blown. thx guys.
RE: need help quick
as far at the fuse goes, cant help you. As far as the diameter of the sway bar, just measure the circumfrence (stretch a string around it or something, then measure the length of the string), divide by pi, (3.14159) and thats your diameter.
alexc
alexc
RE: need help quick
Yea, Like ttoppedaerocoupe said, just wrap a string around it and than measure the string. The bushing is not that hard to replace at all. If you need to drive the car without the sway bar nothing will happen... it will just wont handle well.
autoedit
09-27-2015 06:37 PM
09-25-2015 06:30 PM
