Hi guys
Hi guys
Hi guys..
I have Cobra 93 302 with pistone only,cam E303,S-trim S/C 14psi ,other all bolt on and i want to ask about 205 AFR heads for my S/C
its agood idea to go with it and whats your opinion??
& for the Intake Manifold which is better in that case ??
Thanks..
Yousif
Thanks..
Yousif
RE: Hi guys
205's are way big for a 302. even a supercharged one.
165's or 185's would be a better choice.
the stock cobra intake manifold is pretty good. you could get the lower ported.
what compression ratio are you running with those aftermarket pistons, cause 14 psi of boost is a lot.
RE: Hi guys
The compression ratio is 9.1
About intake manifold what is installed on my car its stock not cobra intake manifold.And i'm thinking about install intake manifold R-Series with BBK throttle 75mm its agood or need bigger??
