Trick flow kit
03-30-2006, 01:20 AM
Trick flow kit
I decided to go with the trick flow top end kit rather than piecing things together, so i looked for it in my summit mag and it says it wont work with 94-95s. Anyone know why this is? Thanks guys
03-30-2006, 01:23 AM
RE: Trick flow kit
on the summitracing.com it doesnt say anything like that. In fact it says it fits through 95.
03-30-2006, 01:24 AM
RE: Trick flow kit
No it does fit you just need to get the elbow adapter.
03-30-2006, 01:29 AM
RE: Trick flow kit
yep, aftermarket intakes were originally designed for the 93 and below. but they make an elbow adapter, which will allow it to fit a 94-95 model, trickflow makes one for about 80-90$.
03-30-2006, 02:39 AM
RE: Trick flow kit
Oh ok so all i need is the elbow adapter and ill be straight?
03-30-2006, 02:53 AM
RE: Trick flow kit
yea man! youre good with the elbow, make sure youre tb, maf, is for 94-95 though. the intake heads cam, etc is for 95 down though.
03-30-2006, 10:05 AM
RE: Trick flow kit
Yeah, for sure! thanks man. Ill be ordering this kit in a few weeks. what injectors should i run with this setup, 24 or 30?
03-30-2006, 12:05 PM
RE: Trick flow kit
24's will be fine.
03-30-2006, 12:42 PM
RE: Trick flow kit
buy the elbow used and save some cash. It's just a piece of metal anyways.....ebay, classifieds.....
24 #er's should be fine, but get an adj. fuel pres. reg. and a dyno tune might help.
jwog666
12-27-2021 08:09 PM
Lethaldosage423
10-19-2015 12:12 AM
flash_xx
10-16-2015 07:23 AM
Drastang
09-30-2015 03:48 AM
