Trans removal
RE: Trans removal
No they're not, they're right on top of the tranny, go underneath your car and put your hand up to where your shifter is, you'll feel four bolts... I actually have my stock shfiter out and my boot off my tranny, i'll take a pic from inside the car so you can see where they are underneath.
RE: Trans removal
Ok, first picture is the shifter in the car, you can see the 4 bolts on the top, and see that the boot is not in your way. 2nd is a top view of the stock shifter, once again, you can see the boot isn't in the way, 4 1/2" bolts. 3rd is a side view you you can see how it fits in the tranny.
[IMG]local://upfiles/16761/0849427D7D9A4093ABA04E985F0745D0.jpg[/IMG]
[IMG]local://upfiles/16761/671FDB2CBCC848F9B6C4A8A96535A876.jpg[/IMG]
[IMG]local://upfiles/16761/05E1D61E3ABC4D2E81A3441661B5EA58.jpg[/IMG]
RE: Trans removal
ORIGINAL: redmustang83596
These are the bolts I need to remove. I know what bolts you are talking about I have seen them.
[IMG]local://upfiles/16370/2F6C576A1DF1423180F2D64A173D9066.jpg[/IMG]
RE: Trans removal
Well then how would I go about getting the shifter out of the car? If I remove the four bolts that bolt the entire shifter to the Trans., then the shifter will be in the car. I will have to tear apart the console to get it out anyways.
RE: Trans removal
ORIGINAL: Liquid_02
Exactly, so what's the problem? aha
RE: Trans removal
Are you changing the shifter or something? Otherwise you don't have to take it out of the car, just leave it there. even-so, you could just take the **** off and slide the shifter out of the boot, there's no need to take out the center counsel.
RE: Trans removal
Yah, the ball slides into a plastic bushing in the tranny, it's not hard to line-up. Just make sure before you bolt the tranny back up and everything that you did get it into the bushing... i made that mistake once.... had to drop the tranny back down all over again.
