Got a stang
RE: Got a stang
I drove his car back when he bought it and another thing that is a mayjor problem is its pretty slow, I mean slower then it should be, its also got 3:73s and it didnt really take off, then once I jumped in my cobra it felt like a viper compared to that thing, maybe fuel problems? of his MAF is bad? what could be causing this??
RE: Got a stang
well im no expert but I'd say your intake setup is way too big for the engine...maybe step down to a 65mm TB eventually for more power. I had a bad maf but it still ran fine, just was slow as ***** lol
RE: Got a stang
i was wrong its 70mm throttle body,today i turned the key on just so that the fuel pump would turn on..then let it sit for like a min and it ran fine. I dont know whats going on, I go to advance auto and get it tested for trouble codes and get back to you guys
RE: Got a stang
you say high flow injectors. so what are they. 24#??? and i dont see anything for maf there. if you have 24# injectors did the previous own get a Mass air flow sensor calibrated for the size injectors you have. im not saying this is your problem cause you may even have the 19lb inj. just curious???
