Got a stang
Got a stang
Well. I got a stang..94 GT, there is one problem with it though. When you start the car you have to let it sit for a little while otherwise if you try to go or even touch the gas in neutral it just dies. Then when restarted. It starts but dies again. What could be the problem. After it sits. It runs great. The car has Trickflow intake, 75mm Throttle body, High flow injectors. Trickflow plugs. I was thinking that the fuel pump is tired and not working to its potential?
RE: Got a stang
is it a manual or AOD?
when u start the car it idles good right?
i'd see how long it can hold an idle and go from there
maybe engine isnt getting gas or too much gas? i'd call up the previous owner and ask him if he messed with the A/F ratio or changed/upgraded the fuel injectors
alot of people buy 24# injectors which are too big for a stock 5.0 (non cobra)
RE: Got a stang
i think a switch or sensor, do you have a check engine light? if its not lit, make shure there is a bulb, and if there is its pluged in! if the lights on you can bring your car to advance auto parts for a free diagnosis...
RE: Got a stang
ORIGINAL: Tims 88GT
neutral safty switch?
"High flow fuel injectors" what is high flow? is you MAF calibrated for the injectors? Since you didn't list any MAF mods, I'm assuming you only have the stock MAF, which could be your problem.
