95' GT shaking too much!!!!?
Hey guys. Have any of you had a problem with your mustangs shaking too much when you start it in the morning. My engine shakes too much when It is at normal rpm, which is roughly about 850 or 900 rpm. the shaking stops when I rise the rpm higher than 1200 rpm. do any of you know what could be the problem. I changed spark plugs recently, and also got new wires, but it kept on shaking. could it be the mass air flow? Any comments will be greatly appreciatedl
Thanks
Thanks
RE: 95' GT shaking too much!!!!?
Well it's hard to say because they all shake, especially if you put a cam in it, but if it's shaking more than it should, it could have a miss or the timing could be off or an injector isn't firing. It's not really easy to solve over the net.
