guages wont light up
Old 04-01-2006, 03:02 PM
FiveLiterRiceEater
FiveLiterRiceEater's Avatar
Default guages wont light up
ok i got my dash and everything off. i was lookin for some burned out bulbs, but they're all good. so now the question is why dont my white face guages light up? i noticed thereswires to each of the guage faces, are the faces like a circuit board themselves?
FiveLiterRiceEater is offline
Old 04-01-2006, 03:04 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: guages wont light up
Did you get the kind that light up or just overlays?
PRO50SC is offline
Old 04-01-2006, 03:10 PM
FiveLiterRiceEater
they were in the car when i bought it. they are overlays, but they have wires connected to them so i think they light up. i just noticed a few weeks ago i turned my lights on and they were real dark. i thought a lightbulb burned out.
Old 04-01-2006, 03:12 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: FiveLiterRiceEater
If they have wires connected to them then they should light. Not sure how they wire though. They prolly need some type of reostat or the like to work. Someone that has them might chime it.
PRO50SC is offline
Old 04-01-2006, 03:17 PM
marx91
marx91's Avatar
your dimmer switch could be bad
marx91 is offline
Old 04-01-2006, 03:20 PM
smkshw
smkshw's Avatar
might be your switch,I don't have the white faced guages but,my interior lights didn't turn on once,and it was the switch..also,I'm sure you did but,did you check your fuses?
smkshw is offline
Old 04-01-2006, 03:39 PM
FiveLiterRiceEater
yeah i checked my fuses last weekend when my brake lights went out. the connector to the brake switch was melted. i havnt check the dimmer switch on this but i did find a switch to change the guages from blue to green tint. it shocked me. im gonna look at the dimmer switch now.
Old 04-01-2006, 07:29 PM
89gtsleeper
89gtsleeper's Avatar
well... I can speak from experience on this one.... a few tips..
1) If it is overlays, and they are not lined up correctly, it cover up some, and in extreme cases, nearly all of the lighting behind it. Mine covers not all but a little bit of it, but I have seen on other fox bodies where it is completely covered.
2) The fuse for the lights could be blown. You can replace this fuse to ttest that theory.
If still not working after swapping the fuse, get a test light with a probe needle, and stick that intowhere the fuse plugs in, and make sure you dimmer switch is turned on to full...
3) If still nothing, move the dimmer switch back and forth alot... On my car right now, the dimmer switch itself is not bad, but the connection to it is very loose and sometimes it flickers, and other times it stays on/off... On mine, I found the sweet spot close to all the way up, and just left it there.
4) If still nothing, but you know it is getting power at the fuse box, then follow the wires up to the cluster, unplug it from there, and use the same test light procedure at this connection... that will tell you if a wire is bad on the way from the fuse box to the cluster.
89gtsleeper is offline
Old 04-02-2006, 12:05 AM
FiveLiterRiceEater
i figured it out. got all my dash torn out and pulled the instrument panel apart. the guages have a wiring harness connected to it. i traced the wires to a little black box. no idea what it is. theres 3 wires going into it. 2 from the guages and a third. so i followed the 3rd to a dimmer switch of sorts. its got a switch that changes the lighting from blue to green, and then a dimmer switch. pretty trick and extremely retarded. none the less, i got it. and ended up having to superglue my dash back on since some ******* broke the top tabs up by the windshield off.
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
lincolnshibuya
12-08-2015 04:37 PM
Explosive
10-02-2015 07:45 AM
folivier
10-02-2015 05:34 AM
Quick Reply: guages wont light up
